RC4 Material mapping size rescaled
Hi all,
Since yesterday (rc4)
The Material -> Texture -> Texture Mapping Size are not saved, or are systematicaly over scaled (not sure).
Anyhow this behavior appears with RH6 service 4 RC
Try:
  • Create a surface
  • Set a floor material with the following:
  • Architectural -> Floor -> Wood -> CARPETMAD light.rmtl
  • Note the texture mapping size: in my case: X: 100; Y:76.67732
  • Save and the document and exit.
  • Open the document
  • You can see now the problem, the texture mapping size has been set to: X: 10000; Y:7667.73163
Thanks - I’ll look into it on Monday.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45414
Same happens here Texture is being re-sized
