if I open old files (this is of April 2018) map sizes are incorrect. As you can see in this image size are all 0,001. The right size should be bigger (1400 for all the axes).
Anyway if I render the image the size of the textures is right.
Hello - the file shows materials with type ‘placeholder’ so I’m guessing that the rendering work was done with a renderer other than Rhino Render, correct? In any case try clicking on this button
to make the material ‘box’ the object. (though the box origins seems to be offset)
Hi Pascal,
with this button I constrain the map size to the size of the object.
Instead the initial dimensions were 1400x1400x1400 (for the top of the furniture)
