Hi @scottd,
how to change the size of the Flamingo tile material? When I change here the values, nothing changes. (Please click on the picture, Discourse cuts off this picture, not nice.)
Thanks
Michael
www.flexiCAD.com
Hi @scottd,
Thanks
Michael
www.flexiCAD.com
same problem - no solution?
Has there been any resolution on this issue? I attempt to change the tile size under the Editing Flamingo Image and it reverts back to the original size after I click OK.
I have the same problem,- that it reverts back after clicking ok.
Same here. Any solution?
This needs urgent fixing. Flamingo people please !!
Had to reverse back to Rhino 5. Works there.
I wasted hours looking for that but found a way to do it:
It works but you can’t save it as a new material. You must proceed that way for each surface that use that material.
If there is a better way, let me know.
Thanks for the work around jacuesmm. After recently upgrading to Rhino 6 and Flamingo 5.5 I’ve experienced the issue mentioned above and it’s kind of wrecking my productivity.
Has anyone found a permanent fix for this problem?
I think it is a problem with mapping. When using Rhino 5 I had a material library and it worked fine. Now, with the same materials there is the problem. The Rhino renderer takes the right material assignement, as at the picture:
edit: all the pictures are taken from the Rhino 6 and the nXt 5.5, the latest releases.
Regards, Jaro
