Can somebody provide an example of automatic adding of the worksession files to the document?
Thanks,
Dmitriy
Thanks,
Dmitriy
Hi Dmitry - just off hand, it does not look like the RC functions support this - @dale, is that correct?
Ok, thanks.
At the moment I am using RunScript for this solution.
You mean something like _-WorkSession _Attach?
– Dale
Yes, correct.
Hi @Dmitriy,
If you are using RhinoCommon, you can use the RhinoDoc.Worksession property to query informtion about a worksession. But to attached a new document, you’ll need to script the Worksession command for now.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43477
– Dale
