Hi
@dale @pascal Is it possible to get attached document file paths in Rhino 5 using C# API?
-@Sarath
Hi @Sarath_Kithiyon,
You can attached documents by scripting the Worksession command using RhinoApp.RunScript.
– Dale
Hi Dale, I have the same issue. I’m trying to find the attached document paths from an existing Worksession.
Hi @dale
The script is not working for the following scenario,
1.Open new template
2. Attach another 3dm file
3. Save the active model and worksession
4. Then run script
Sub GetAttachedDocPath()
Dim fileName
fileName = Rhino.WorkSessionFileName
If IsNull(fileName) Then
Rhino.Print "WorkSession Not Saved"
Exit Sub
End If
Rhino.Print fileName
Dim arrModelPaths, strPath
arrModelPaths = Rhino.WorkSessionModelNames
If IsNull(arrModelPaths) Then
Rhino.Print "No Attchment"
Exit Sub
End If
For Each strPath In arrModelPaths
Rhino.Print strPath
Next
End Sub
Following your instructions, the script works as expected. What am I missing?
– Dale
Hi, @dale,
After step 4,
It always returns "WorkSession Not Saved"
Note: Once close the model and open again it works.
Sorry, I can still not repeat what you are report. I am using Rhino 6, by the way. Have you tested with this version? Otherwise, I’ll need some files and perhaps a video.
That said, even if this doesn’t work correctly in Rhino 5, it won’t be fixed…
– Dale
