Hi guys,
Does the clipping plane work in raytraced display mode on mac? I can’t make it work.
Hi - that’s still on the to-do list.
Hi Wim, thanks for letting me know
Does this work in Windows? Just ran into the same challenge today.
Not in v6, but in v7 there is a irst iteration of it.
Hi I have discovered the same issue as others above…clipping planes not working in raytraced view. I just wanted to double check that there is still no fix for this at this stage that I can download? Are we still waiting for this in rhino 7 or is there a test version out I can try it on? Thanks for your help.
You can download Rhino WIP and use clipping planes there with Raytraced.
It worked, thanks
Amazing!
glad it worked for you. I can spend the rest of the Sunday less stressed.
