I can not figure out why Raytrace mode locks up my system, it’s not underpowered by any means.
Everytime I switch to Raytrace the GPU goes to 100% usage and everything on my system locks up.
Is there some settings I need to change. Here are my specs.
i9-12900K
Windows 11
64gb RAM
AMD Radeon Vega 56 GPU
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Radeon RX Vega (AMD) Memory: 8GB, Driver date: 10-17-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 23.11.1.231017
> Accelerated graphics device with 7 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 2.1
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-17-2023
Driver Version: 31.0.21905.1001
Z-Buffer depth: 24 bits
Total Video Memory: 8120 MB
Not sure why it would be bogged down - is this with even just a simple box?
Since you are driving two separate displays with the GPU it can cause some resource contention issues.
Also, your OpenGL level is not set to the highest - did you turn it down for some reason?
I haven’t followed AMD GPU development much, but the Vega 56 is based on GCN5 and I believe the newest/upcoming is RDNA3 architecture. I am under the impression that Cycles performance is better on RDNA-based architectures. Again, I don’t follow this much, although I have tried with an AMD Radeon Pro W7800 and that appeared to be working reasonably well.
Not sure what to advise here - maybe try Rhino 8.3 service release candidate (Help > Check for Updates…, set update frequency to service release candidate), see if it is any better?
I do use two monitors and I did turn down the OpenGL to see if it changed anything, but it didn’t.
I installed Rhino 8 on another PC with a Quadro P2000 GPU and it works fine, slow, but it doesn’t lock up the PC. The VEGA 56 locks it up even with a simple cube.
I’ll try the release candidate but i may have to switch to an NVIDIA card.
I used to have issues back in the day when I was using ATI AMD cards. I went with an Nvidia FX3800 in those days, and never turned back.
I used to dream about going high end with ATI AMD, but these days there’s really no point anymore. Nvidia is dominating.
I built a new computer last yr for a colleague, with an RTX 4000. I basically have duplicate parts for another one I plan to use. Haven’t done extensive testing yet, but I’m confident these two computers are beasts.
