Hello!
I would like to ask you.
What is the major logic of this pattern with 90 degrees?
I need to have curve that falls on itself without overlap.
It’s a grid with points_____and move on to the closest points …and loop tools???
Thank you for your help!
That’s some sort of “variation” of a Maze (Google that) problem. Not that difficult to address via code … but I have no idea what’s possible with components.
Another take could be a modified Hilbert curve (the classic algo is a bit monotonous).
Another take could be a Hamiltonian path on an ortho quad Graph (but that’s kinda killing a mosquito with a bazooka).
Finally … some 2d version of this:
Thanks for the help, Peter.
I will try to find the way without C# Python.
Parakeet has a maze tool
You’ll waste your time.
For instance attempting ro do a Hamiltonian Path without some advanced heuristic backtracing (in order to deal with the “usual” N factorial Elapsed time) is kinda 3rd marriage: triumph of hope vs experience,
That said avoid any TSP (Traveling Salesman) algo: not the way to cut the mustard on that matter
Done with some Pythonic magic! ![]()
It use recursive backtracking to make a maze out of any mesh.
The A* algorithm can be implemented as a solver.
Hello
this question has already been asked. See this thread. For your problem I’ll use an offset of the labyrinth path of wall.
So see that
And if not 90° see this
