After creating a grid of triangles (on a plane or on a surface) I need to ‘randomly’ group triangles as shown below. So triangles would remain either a single triangle or grouped into 3 triangles to create a trapezoid
Thanks
Thanks
To be more specific, I am trying to re-create the ‘first’ layer of panels on the Puzzle Ball Theatre facade shown below.
Hello
you’ll have certainly to make your custom tool to do that.
With my plugin Nautilus I can get that
or that
Hello, is there a way to make the first pattern image you have attached on a flat rectangle/square surface and not a sphere? @laurent_delrieu
This works perfect! Is there a way to randomize it less, making it more regular?
Hello I am not sure it will work. You can use more regular seed points.
Also I have another clustering tool that makes cluster quite convex then tries to expand branches.
Stripper vould surely also be used…
