Random Contours curves generation
Hello there, I am wondering if there is a plugin or script that can generate a pattern similar to the .attached image.I tried nautilus and Field lines both are giving me curvy, gradient and uniform.but i want it to more random ( curves and also distance), tweening also i tried that also time taking and to develop a new variation i have to totally remodel.
any suggestions or ideas to develop the pattern in GH
Noise could do this
Something like that was presented here
Hi @laurent_delrieu i am a great fan of you, most of my gh scripting problems are solved by you only, but i want more like canyon or topographic, the above aleady i am having.
please help me out, teach me.
can you share the script of above posted images?
Hello
here are some files
noise 2.gh (23.0 KB)
noise 1.gh (16.8 KB)
BUT I think you didn’t describe well were are your problem/needs.
If you have curves why not sharing them with the script you made ?
Also possible to use curves to draw valley and mountains
Uses these curves to calculate heigths, then you can use warp to make random/noise movement …
Your statement is wrong, if the tools has not what you want it is perhaps you need more than one component to do what you need. My examples are done using Nautilus mainly.
yes i totally agree with what you told, and thank you very much this is what i wanted.
and if you have anytime, help me with more explained how to use curves and points in this script, i am total newbie.
