Randon line pattern with dots
Hy guys,
any Idea how to create this kind of pattern in grasshopper.
Thank you.
Hello
there are tons of ways.
For the dots it is a regular grid.
The curves could be taken from topographic data or a scalar field. Then you just remove all dots that are too near from the curve or too near from a numeric value (from scalar field).
thank you @laurent_delrieu for giving hint.
how can I create random lines? Do you have any grasshopper defination for it?
thank you
Curve are the place where scalar field has the same value.
You can use plugin like IsoPod, Nautilus to get the iso curves.
Scalar field could be an equation, a noise, and why not a topographic data (elevation as a function of (x, y)).
Here some of the command in NAutilus plugin
You are at the command and as you don’t post any other context, giving a definition has a low probability of usefulness. Please read that
