[R8 Regression] Grasshopper baked objects slowing down performance
I think the video is quite self-explanatory.
Below is the attached file.
R8 Bug and Regression.gh (653.8 KB)
Way to replicate the bug:
  1. use my file to bake the curves,
  2. make a block of all the baked curves.
  3. double click to enter the block edit mode
  4. exiting the block edit mode by closing the block edit window
  5. the issue would appear.
I also notice other instances with similar issue but this is the only instance where I can isolate the geometry and replicate the bug consistently.
@stevebaer
@wim
FYI:
I also notice a weird blink upon selecting these objects. It happens at 0:09 in the video.
This is not consistent with how other objects are selected.
Hi Wiley,
I’m not able to repeat in our latest daily build (8.18)
Please run SystemInfo and post the results.
Do you know the previous version that didn’t have the behavior?
I just tried using safe mode and i couldn’t replicate the behavior.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 9-13-2024 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
  Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 9-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.09
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 9-13-2024
  Driver Version: 31.0.15.5309
  Z-Buffer depth: 24 bits
  Total Video Memory: 16376 MB
  C:\ProgramData\Beam\App\netcore\Rhino\RHINOBEAM.dll	"MKS BEAM"	1.12.0.4
  C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll	"Enscape.Rhino8.Plugin"	4.3.0.1189
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp	"WebBrowser"
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp	"RhinoScript"
  C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp	"AnimationTools"
  C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp	"IdleProcessor"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp	"Legacy Rhino Render"
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp	"BlockEdit"	8.14.24345.15001
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Start by disabling the active 3rd party plugins.
The other aspect that Safe Mode disables is the Video Driver.
