Has anyone encountered this issue? After baking from Grasshopper, it becomes extremely laggy when immediately switching to shaded mode. However, if I reopen the baked file and use shaded mode, it is no longer laggy.
I guess your object is a bit more than just a single surface…
Rhino needs to compute the render mesh.
If this is an issue, use the wiremesh mode for quicker drafting and baking.
However, what’s strange is that when I reopen the baked file and use shaded mode, it runs smoothly. It’s quite inconvenient to have to close and reopen the file every time after baking.
Hi Jack -
Please post a .gh file that we can try and the output of the Rhino SystemInfo
command.
That might be because the render mesh has already been calculated.
When I upgraded Rhino 8 from SR7 to SR14, the issue was resolved, although I didn’t understand the reason behind it.
