R8 cage edit bug
It’s fantastic that Rhino 8 lets me use cageedit on a bunch of surface points, but when I try it with subd points, it results in garbage. I think it only happens when the number of points on the control is lower than the number of points selected, but I haven’t tested a lot. The example images here are with a 2x2x2 control.
Hi Peter - thanks, I see some messiness here as well. It looks like the cage is treated as a local cage on the entire object. Or something.
