A checkbox to have all commands have their options perm sticky. (Ex: Extend, ExtendSrf, Pipe, Array etc.)
Dimension commands to have a sticky option of an offset, so you can pull a bunch of dims with the same offset not worrying about lining them up pretty.
What is that?
That the options you select in a Rhino command stay that way until you change them, even after closing and opening rhino.
Oh, well, I support this request
I had the same issue about setting until I decide to make my own buttons because some times I needed them as default too,
also to configure some shortcuts like the images below:
Loft with straight section for developable surfaces
Surface from UV curves to use as base surface for FlowAlongSrf
MergeAllFaces after Boolean Union:
about the dimension offset it could be awesome, yes. perhaps a workaround with the connected option.
