So in Revit 2025, I have installed the stable release R.I.R
Trying to select the revit curtain wall using the ‘Graphical Element‘ - Revit component inside grasshopper, but when connected to the ‘Analyse Curtain wall type‘ component there appears to a break point error
Well the component is executed after ignoring the error but,
The Inspect element cannot retrieve any data as a result of the break point error
So could any of the experts care to explain the problem which is happening here
Hello Japhy, would uninstalling the present stable release of Rhino.Inside.Revit installed currently and going with latest builds help resolve the situation by NOT throwing the breakpoint errors?
Is it Revit 2025.4 or Revit 25 you have used to get no errors, it’s the parameter type error which comes when R.I.R is been trying to access Revit 25’s API or atleast that was the case for me
Also, could you share the Revit version which you have used to obtain the outcome without any issues
Still i could not get it resolved, will provide the files for you to go through
Most probably it shall work on your PC I guess , because it’s simply a Element Type has to be read by the ‘Analyze Curtain Wall‘ component , but the below image shows what happened every time when i used ‘Element Type‘ to pass in the ‘Type‘ as a Data to ‘Analyze Curtain Wall‘
It throws the same error
The .rvt file is Revit 2025
The .gh file is the latest stable build of GH
The Goal was to actually select a ‘Curtain Panel Family‘ and have its parameters by ‘Inspect elements‘ component and other GH components, so it’s just a basic facade automation
Like this one
But first problem being that the curtain wall type has to be recognised in order to be going to the next stages
If I can get the ‘Analyse Curtain Wall Type‘ recognise , sure i shall use the ‘Inspect Element‘ to find the parameters, then manipulate them, and yes I should be having a family where that specific parameter is an Instance based parameter, so to have many values
But all can happen once if the first ‘Analyse Curtain Wall Type‘ component be able to read the ‘‘Element type‘ from the ‘Graphical Element‘- which has the Curtain Wall on it
ive tried using the ‘analyze curtain wall‘ component from the old 2021_GH_V1 script and it did recognize the graphical element which was referencing the revit curtain wall
so able to inspect and bend the parameters to my will inside the curtain wall
thank you for you help,
but the ‘breakpoint error‘ still persists as it did before for the latest release in the curtain wall
’Graphical Element’-referencing Revit Curtain wall unable to be detected by the ‘Analyze Curtain Wall Type‘
