Question: Outline/contour of both open & closed curves (Grasshopper)
I am on Rhino7 and this concerns Grasshopper. I like to generate the outline/contour of a combination of closed & open curves. I have tried “boundary surface” and other components, but they all fails for different reasons.
What would be the simplest way to connect these curves and generate a list of single outlines/contours in a list?
Thank you for taking the time!
Helge
Closed & Open Curves.gh (8.2 KB)
You can create Region intersections like this:
Closed & Open Curves.gh (11.7 KB)
Hello Martin,
Thank you, that works very well! “Region Union” is the key. :slight_smile:
Now I’ll have to work out what to do if the primary (closed) curve has a concave curvature, however, that should not be much of an issue.
Helge
Extend the ends of the short curves and then use Region Difference
Closed & Open Curves.gh (14.8 KB)
Thank you, Martin, that is a great idea. Will do!
Have a nice day!
