Curve Boolean on open curves in grasshopper?
Hello forum,
I have a seemingly simple problem, but since I am not very experienced in GH, I don’t seem to find a solution. Maybe someone here can help?
I have a set of coplanar open curves and I would simply like to get their outline using GH, as if you would by pressing on the “outside” in the CurveBoolean Command in Rhino. Like so:
To:
I don’t care about closing curves inside the closed curves for now.
There seem to be loads of loosely similar topics in the forums, but after hours of searching I still couldn’t find one that fit my particular problem:
The boolean region component doesn’t work, because they are open curves.
I though with the boundary component I could get there but it didn’t work either… I have even managed to shatter the curves at their intersections but the boundary component still won’t do it.
Is there a way to do it with the standard GH components? If not, does anybody have a script that would work (I don’t really know how to make one, so…) ? or know any plugins for Mac?
Thanks in advance for any help :slight_smile:
You can use Heteroptera Geometric Region
Works like a charm! Thank you very much for the quick answer!
Hey btw… for any one who wants it:
I maybe found a rudimentary way to do it without having to download an entire plugin…
It’s based on several forum posts… dunno, might not be as reliable as Heteroptera though…
Many know some way like this. The issue is the slowness of area + split surface + region union when the amount of things is more.
I’ll remember that! Thanks :slight_smile:
This worked for me when the Heteroptera geometric region didn’t because I had 2 overlapping curves. thanks!
I had a similar situation a while ago.
Check this link, curve Boolean script is further down
