I am trying to use Quad Remesh C# API but not getting ‘Convert to SubD’ setting option in the API. Could anyone guided me to create Quad Remesh with ‘Convert to SubD’ option using c# API.
QuadRemesh is only responsible for making Meshes. Once you have your Meshes you will then need to create a SubD from the newly created Meshes using the methods available in the SubD classes.
https://developer.rhino3d.com/api/RhinoCommon/html/Overload_Rhino_Geometry_SubD_CreateFromMesh.htm
