How to convert QuadMesh to SubD in RhinoCommon likewise _ToSubD in GUI?
I would like to convert a QuadMesh object to a SubD in Rhino using RhinoCommon, but I want to avoid using [rs.Command(“_ToSubD”)] or any command-line calls.
In the GUI, I usually use _ToSubD with the following options:
  • Mesh Use = Control Points
  • Mesh Crease = Yes
  • Mesh Edge = Yes
  • Surface Use = Position
  • Surface Edge = No
However, RhinoCommon’s SubDCreationOptions exposes different parameters, and I’m not sure how to set them to match the GUI options above.
Is there a way to achieve the same result as _ToSubD with these options using only RhinoCommon?
Or is there another function in RhinoCommon that uses the exact same parameters as _ToSubD?
Either approach would be a solution for me.
Additionally, when using Rhino.Geometry.Mesh.QuadRemesh() to remesh to a quad mesh, is there a way to directly convert the result to SubD as in the GUI, without using command macros?
Any advice or code examples would be greatly appreciated. Thank you!
Hi @Young_Geon_Park,
Try using SubD.CreateFromMesh.
– Dale
Thanks to your reply.
I know that by using the command in rhinocommon to convert mesh into SubD, but i have a problem with the params.
There are a few params to control the conversion, but it is different with GUI command _ToSubD, so i wonder how to convert as same as the GUI command.
Thanks
For meshes, this should be all you need:
#! python 3
import Rhino
def GetSubDCreationOptions(UseMesh, MeshCreases, MeshCorners):
    options = Rhino.Geometry.SubDCreationOptions.Smooth
    # True = ControlPoints, False = Location
    options.InterpolateMeshVertices = UseMesh
    if MeshCreases:
        options.InteriorCreaseTest = Rhino.Geometry.SubDCreationOptions.InteriorCreaseOption.AtMeshDoubleEdge
    else:
        options.InteriorCreaseTest = Rhino.Geometry.SubDCreationOptions.InteriorCreaseOption.NONE
    if MeshCorners:
        options.ConvexCornerTest  = Rhino.Geometry.SubDCreationOptions.ConvexCornerOption.AtMeshCorner
    else:
        options.ConvexCornerTest  = Rhino.Geometry.SubDCreationOptions.ConvexCornerOption.NONE
    return options
– Dale
