Quad Remesh popup bug
After the last update, the quad remesh popup is cutting off the text that displays how many faces the process created. I can’t expand the popup window by dragging on the edges, either (don’t know if that was ever possible, never needed to before)
Is anyone else having this issue?
hmm, this looks like a DPI display scaling issue with the dialog. I assume you have your Windows display scale set to something greater than 100%? Thanks for the report, we can get this tidy’d up.
yes I have the display scale above 100% for legibility at a distance on a high res screen.
thanks for putting it on the list
RH-88437 is fixed in Rhino 8 Service Release 23
Thanks!
