Python – Set Linear Dimension Text Inline (Rhino 8)
In Rhino 8 (SR16), using Python in the ScriptEditor, how can I:
  • Select an existing linear dimension
  • Set its text to inline, positioned inside the dimension line, between the arrowheads
Is there a RhinoCommon property or method to change this text position via Python?
Thanks.
Hi @Daniel_Senff, try below script:
#! python 2
import Rhino
import scriptcontext
def DoSomething():
    dim_id = rs.GetObject("Select Dimension", rs.filter.annotation, True)
    if not dim_id: return
    dim_obj = rs.coercerhinoobject(dim_id, True, True)
    if not isinstance(dim_obj, Rhino.DocObjects.DimensionObject): return
    s = Rhino.DocObjects.DimensionStyle()
    s.CopyFrom(dim_obj.Geometry.DimensionStyle)
    s.DimTextLocation = Rhino.DocObjects.DimensionStyle.TextLocation.InDimLine
    dim_obj.Geometry.SetOverrideDimStyle(s)
    dim_obj.CommitChanges()
DoSomething()
_
c.
The code worked perfectly :+1:
Thank you very much for the help — I really appreciate it!
