To put dim text below dim line (a hidden/old option).
This works:
dim = Rhino.Geometry.LinearDimension(plane, pt1, pt2, pt0)
dim.Aligned = True
dim = sc.doc.Objects.AddLinearDimension(dim)
dim = Rhino.DocObjects.ObjRef(dim).Object()
dim.Geometry.TextLocation = Rhino.DocObjects.DimensionStyle.TextLocation.BelowDimLine
dim.CommitChanges()
This doesn’t:
dim.Aligned = True
dim.TextLocation = Rhino.DocObjects.DimensionStyle.TextLocation.BelowDimLine
rajaa
(Rajaa Issa)
May 25, 2021, 3:43pm
2
Hi, is this a RhinoScript code?
Can you share a more complete code sample hat I can run at my end? Thanks.
import Rhino
import scriptcontext as sc
plane = Rhino.Geometry.Plane.WorldXY
pt1 = Rhino.Geometry.Point2d(0, 0)
pt2 = Rhino.Geometry.Point2d(10, 0)
pt0 = Rhino.Geometry.Point2d(0, 5)
#dim = Rhino.Geometry.LinearDimension(plane, pt1, pt2, pt0)
#dim.Aligned = True
#dim = sc.doc.Objects.AddLinearDimension(dim)
#dim = Rhino.DocObjects.ObjRef(dim).Object()
#dim.Geometry.TextLocation = Rhino.DocObjects.DimensionStyle.TextLocation.BelowDimLine
#dim.CommitChanges()
dim.Aligned = True
rajaa
(Rajaa Issa)
May 26, 2021, 5:03pm
4
I do see it.
is basically ignored if set up during the creation of the dimension, and only takes effect if set afterwards. This is perhaps a bug and will investigate further.
Added a bug here…
Alain
(Alain Cormier)
May 28, 2021, 8:25am
5
I know this is not intuitive but setting the TextLocation (or any other value that comes from the annotation style) attempts to override the annotation style TextLocation value but in this case no annotation style is associated with the dimension until you add the dimension to the document.
Instead of calling the LinearDimension constructor you can associate an annotation style with the dimension by creating the LinearDimension like this:
aligned = Rhino.Geometry.AnnotationType.Aligned
ds = sc.doc.DimStyles.Current
v = Rhino.Geometry.Vector3d(0,5,0)
pt1 = Rhino.Geometry.Point3d(0,0,0)
pt2 = Rhino.Geometry.Point3d(10,0,0)
pt0 = Rhino.Geometry.Point3d(0,5,0)
dim = Rhino.Geometry.LinearDimension.Create(aligned, ds, plane, v, pt1, pt2, pt0, 0)
I’m having troubles with creating dims that aren’t strictly horizontal:
v = Rhino.Geometry.Vector3d(-5,0,0)
pt2 = Rhino.Geometry.Point3d(0,10,0)
pt0 = Rhino.Geometry.Point3d(-5,0,0)
Alain
(Alain Cormier)
July 6, 2021, 4:07pm
8
I’m not sure exactly what kind of dimension you’re trying to create but the last argument of the Create
function is the angle.
I figured it out:
pt2 should go before pt1, otherwise after manual dimension edit, it mirrors along the start - offset point line.
Rhino.Geometry.LinearDimension.Create(aligned, ds, plane, v, **pt2, pt1**, pt0, 0)
Is this how one would check if the angle should be positive or negative?
if v.Y < 0: angle = -angle
