I know changing text size/height is an option here, but I want to change its position. It is possible?
Manually: You can turn on controlpoints for dimensions and drag the points for the text to a better position.
HTH
-Willem
Thank you, that was it!
this help?
Option Explicit
'Script written by Pascal
' RMA
'Script version Wednesday, December 12, 2012
Rhino.AddStartUpScript Rhino.LastLoadedScriptFile
Rhino.AddAlias "DimensionOffset", "_NoEcho _-Runscript (DimensionOffset)"
Private OldDist
If IsEmpty(oldDist) Then
OldDist = 1
End If
'Call DimensionOffset()
Sub DimensionOffset()
Dim adim: aDim = Rhino.GetObjects("Select dimensions to modify.", 512,, True)
If Not isArray(aDim) Then Exit Sub
Dim dist: dist = Rhino.GetReal("Set Dim text distance", oldDist)
If isNull(dist) Then Exit Sub
OldDist = dist
Dim sDim, n, p1,p2,p3,p4
Dim vecX, vecY, d1, d2, plane, targ
Dim testPt, dirpt, idx
Dim p(3)
Rhino.EnableRedraw False
For Each sDim In aDim
If Rhino.IsLinearDimension(sDim) Or Rhino.IsAlignedDimension(sDim) Then
Rhino.EnableObjectGrips sDim, True
p(0) = Rhino.ObjectGripLocation(sdim, 0)
p(1) = Rhino.ObjectGripLocation(sdim, 1)
p(2) = Rhino.ObjectGripLocation(sdim, 2)
p(3) = Rhino.ObjectGripLocation(sdim, 3)
d1 = Rhino.Distance(p(0), P(1))
d2 = Rhino.Distance(p(2), p(3))
testPt = p(0)
dirPt = p(1)
idx = 1
If d1 > d2 Then
TestPt = p(2)
dirpt = p(3)
idx = 3
End If
VecX = Rhino.VectorUnitize(Rhino.VectorCreate(dirPt, testpt))
Targ = Rhino.PointAdd(Testpt, Rhino.VectorScale(VecX, Dist))
Rhino.UnselectAllObjects()
Rhino.SelectObjectGrip sDim, idx
Rhino.Command "_Move W" & Rhino.Pt2Str(dirpt,, True) & "W" & Rhino.Pt2Str(Targ,, True)
Rhino.EnableObjectGrips sDim, False
End If
Next
Rhino.EnableRedraw True
End Sub
