Python error on grasshopper
Anyone else has got this problem?? i’ve lost all of my scripts…
And, whats does the second image mean??
I think it is R8 vs R9 WIP problem.
Thank! it’s been a completely mess… all of my python3 components have disappeared… i’ve lost a huge ammount of work
You should probably let @eirannejad know. Sounds like a potentially serious issue.
thanks for answering… It deletes directly the component
don’t know if there are other cases like mine, any idea @Gijs @eirannejad ??
Thanks in advance
SystemInfo | Rhino 3-D modeling you should probably run this command and paste results to this post.
you were right
Rhino 8 SR30 2026-4-13 (Rhino 8, 8.30.26103.11001, Git hash:master @ 3ad61623b0ac4561e2f13265580c56a9f50596d8)
License type: Commercial, build 2026-04-13
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.26
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.5.1\byRhinoGadget.rhp “byRhinoGadget” 1.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.5.1\byRhinoGadgetPlus.rhp “byRhinoGadgetPlus” 0.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\BlockEditNew\2.1.4\blockeditnew.rhp “BlockEditNew” 2.0.0.0
C:\Users\Usuario\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\import_STL.rhp “STL Import”
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.30.26103.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.30.26103.11001
sorry, forgot it… i was a bit stressed!
Hi, if you haven’t saved the .gh fle it shouldn’t have changed or deleted anything.
It looks to me like the second window is offering to convert your Rhino 8 Python components into Rhino 9 format. However it is warning you that after conversion, they’ll no longer be usable in Rhino 8, should you uninstall Rhino 9, and reinstall Rhino 8. Personally I’d recommend backing up your Rhino 8 .gh files, but presumably there is lots of confidence in the conversion process.
Have you got a non-critical example file to test this conversion on, or does that need uninstalling Rhino 9 and installing Rhino 8?
Or just make a copy of your file in File Explorer, and try the conversion on that?
it keeps deleting my phyton components… no idea
not sure how time-stressed you are , but if it is critical, you can also call/email mcneel > Rhino - Contact Us
@nachetz I am sorry for seeing this a bit late but would like to know how to replicate the problem. Are you trying to open Rhino 9 grasshopper files in Rhino 8 or the opposite?
Hi Ehsan !
i’m trying Rhino 8 grasshopper file in Rhino 8… Always the same PC
If you need i can share the gh file, just tell me
@nachetz It would be great if you can DM me the offending file. Somethings is probably written incorrectly in the definition. I am testing this locally as well and so far can not replicate
