Rhino 7 Grasshopper Python Component not working in Rhino 8
R7 GH script with one single default Python component:
Same Script when opened in Rhino 8, the “old” Python component is unrecognized in R8:
How do I get this working, I’m sure it’s something simple. cheers!
(using R8 SR13 and can’t even see the old python component when I search for it)
unnamed.gh (2.2 KB)
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31GB)
.NET Framework 4.8.9282.0
Computer platform: LAPTOP - Plugged in [81% battery remaining]
Primary display: Intel(R) Arc™ Graphics (Intel) Memory: 128MB, Driver date: 1-13-2024 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 11-6-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.14
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2024
Driver Version: 32.0.15.6614
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
Really struggling finding a solution here, any help would be much appreciated. So strange that I’m missing the “old” Python component from R7 GH scripts.
Try installing Everything and search for ghpython.gha to ensure that you have exactly two, one for Rhino 7 and one for Rhino 8:
You might also try disabling any third party Grasshopper plugins. And repairing your Rhino 8 install.
I have just found out that Python is being disabled by the Tekla GH link for 2023 versions and older.
"The old python component from Rhino 7 causes the GH component to crash in TS 2023 and older when using Rhino 8.
The file that powers the old python component is “GhPython.gha” in C:\Program Files\Rhino 8\Plug-ins\Grasshopper\Components. Therefore that file is being disabled when you launch the GH component using Rhino 8 in Tekla 2023 or older. The new scripting component in Rhino 8 isn’t affected by disabling this file.
In Tekla 2024 and Rhino 8.6 or newer the old ghPython isn’t an issue, so there you could re-enable the file by removing the “.DISABLED” extension from the file:"
Wow, that’s a pretty invasive move. But at least they documented it.
