Hi, I remember seeing a video that someone posted where they were fitting a SubD surface to a Mesh (I think) by using the Pull to Surface command to pull the SubD control points to the mesh surface.
Does anyone know where I can find this video ?
Regards,
Mike.
Hi MIke - I don’t know about the video, off hand but it is pretty straightfrward , should ‘just work’ though you might want to pull edit points and not control points at least in some cases:
Thanks Pascal, this is a neat way to get a starting surface from scan data.(polygon surface)
Hi Kyle,
That still isnt the video that I have seen, but it is a great video ! Thank you !
My main interest if creating SubD surfaces from scan data (Meshes) so this works perfectly.
The applications are endless !
Regards,
Mike.
quadremesh the scan, then use the ToSubD command
