Pufferfish - Offset Surface - Both sides (Doesn't Work. Help!)
I had a problem using the Pufferfish’s Offset Surface. (“Both Sides” doesn’t work!)
1,2,3 Pictures of the Problem.
The 4th Picture is what i wanted to get finally using “both sides”.
I’d Appreciate it if you guys tell me why this kind of problem occurred.
Plz Help! T_T
It works fine, the input is not a Boolean, read the input description. it takes a value (negative of distance if you want equal both sides), or you can give it its own number negative to have different amount offset on each side, or you can give it different amount positive and offset the entire geometry off center. Always read inputs.
Thx! I’ll try again
I saw someone use BooleanToggle.
How that was possible…? I saw using Toggle and that was working.
hmm…
Thanks to you, I was able to solve it.(Not using Toggle so it Works T_T)
Probably an old version or tutorial. Was that way few versions ago. The way it is now let’s you have more control.
