Hello everyone,
I have a problem with the Pufferfish plugin since last week, whenever I open the file, a warning message (please see the attachment) appears. If I reinstall the plugin, or just ignore the message, I still get the same error. And when I open the file, the Offset Mesh and the Rebuild mesh components are blank and the toolbar disappears after a while, as you can see in the attachment.
I tried to keep the Pufferfish V3, but the result was the same (Missing Mesh and the Rebuild mesh components and the toolbar disappears after a while)
I tried to keep both Pufferfish V2.9 / V.3, some of the files showed missing both Offset Mesh/ Rebuild mesh while others showed missing the Offset Mesh only (And the toolbar disappears after a while).
I would greatly appreciate your kind help to fix this error please.
Thank you so much,
Nada
