Object properties panel empty
Hi there
Since douple days my object-properties-panel is emtpy. It’s there, but it’s not displaying the content of the panel.
Here’s a screenshot.
Restarting the App or Computer doesn’t help. Also uncheck and check the properties-panel does not work.
I’m wondering where this is comming from. I havent found anything related in the forum.
Cheers Beyon
Hi @Beyon
Start by running the SystemInfo command in Rhino and post the entire result here - that’ll give us a bit more to go by. Might be a Windows update making your graphics driver(s) obsolete and in need for an update.
HTH, Jakob
Hi, Thank you. Usually everything should be automatically updated.
Heres the report:
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Educational, build 2022-10-09
License details: Cloud Zoo
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Unplugged [33% battery remaining] ~38 minutes left
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-4-2022 (M-D-Y).
Primary OpenGL: NVIDIA RTX A5000 Laptop GPU (NVidia) Memory: 16GB, Driver date: 6-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 513.29
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-22-2022
Driver Version: 30.0.15.1329
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Users\yanni\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21349.1646
C:\Users\yanni\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Users\yanni\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp “MeshCommands” 7.23.22282.13001
Hi Beyon -
What happens when you disable the 3rd party plug-ins in the Plug-ins manager and restart Rhino?
hi wim,
no that doesnt work either.
Hi Beyon -
Someone just reported the same issue and, in that case, rebooting the machine made things work again. Have you tried that?
I did a reeboot but it didn’t worked. Yesterday it just appeared again in the middle of the day, no reboot whatsoever.
What was the most funny thing about all this was, that the same panel in Vectorworks had also disappeared…
