Projecting patterned image on Convex surface
Struggle bus…
I’m trying to project a rastered image(linework) onto a convex surface to perforate the surface. This is an architecture project where with a convex skin system that needs to be perforated so I am attempting to project a perforation pattern onto the surfaces.
I rastered an image in Illustrator and can bring it into Rhino but I have been unsuccessful so far using Project command which distorts the image because it projects the image in a linear path, drape command doesn’t seem to work either.
Any help would be appreciated!
Hi Jesse- it sounds like you’ll want to bring this image in as a texture to be used as a transparency map in a material. If you actually want to pop the holes out by trimming the surface, you’ll need to bring them in as curves - it might be just as easy to make the pattern in Rhino as well.
Jesse -
Paneling tools gives you a extra commands that may help map panels on the shape:
http://wiki.mcneel.com/labs/panelingtools
is there a vimeo explaining this process at all? I had brought in the .ai file but in rhino seems more precise
Hi Jesse- general mapping and texturing -
http://docs.mcneel.com/rhino/5/help/en-us/properties/texturemapping.htm
