As you see here I constructed a hull around a solid and applied a opacity texture. Is there a way to convert the perforated surface into real geometry? Pls note that I want to convert shapes of different textures.
Thanks! Hannes
Thanks! Hannes
I can’t think of a way to do it directly / in Rhino, but I do have a work-around. I’ll use this image as the example:
Was considering this a bit as well, will come back soon with updates. As I know you can do it in Modo https://www.youtube.com/watch?v=ijN2o6f5t7U And just wanted something like this in Rhino, this would be awesome for quick design evaluations and concepting… So just use black and white images and convert the opacity/alpha channel to meshes or nurbs. Would be great for the future.You could then use the generated geometry and reverse engineer a proper model.
My main issue would be control, as you could easily use photoshop on a second screen to tweak the texture and hit save to apply on rhino model, this would be tedious with Illustrator. But maybe it’s a good way to start this way in Photoshop and with the best fit get the texture into Illustrator and reconstruct the AI and then use your workflow. Heureka! Just thinking and writing. Thanks Dave for your input!!
you can try the Heightfield Command. It will depend a lot on the image and what you want to achieve…
Hello Suzanne.
Never knew it is a she let alone she had a name.
-Willem
