Hi everybody,
I’m designing a pattern to project on a revolved surface and I’m in trouble with one of the directions (green line) I want to project, matching the CPlane I created (45ºZ from original CPlane).
I need to project a part of the pattern attending this direction with the _Project command because I’m using the History (Project>Symmetry>PolarArray) to modify the original curve (magenta) while I’m able to see how it is dropped on the surface.
Is it possible to _Project using the CPlane direction in stead of the World Plane directions as usual?
I’ve tried with a Plan CPlane view but it stills launching the curve with the original X or Y direction.
Any alternative workflow that doesn’t crash the History?
Thank you!!
