Does anyone have any idea why I am not able to project the straight lines in this file onto the poly surface? Any advice is greatly appreciated.
Hello - keep in mind that Project, unless you tell it otherwise uses the current CPlane normal as the projection direction - dunno if that is what matters here…
Right. What I’m talking about is just a weird deviation from where the line should fall on the surface…
Hello - please post a file with the curves and the target objects.
Sorry, I thought I already posted this.
Hi Mike - set the document tolerance to .001 and it should clean up the projections.
Thank you, I will give that a shot tomorrow.
