Hi everybody!
I want to project curve to mesh with parametric slope 1:X.
It is easy to do it in civil, but i think it can be done in rhino+grasshopper
How can i do this?
I will be glad of any help
ERROR 23-04-1.gh (7.0 KB)
Hello
you question is not clear, do you speak of the slope of the projection or slope of the mesh.
If it is the projection use Project along
You have many ways to make the vectors
- Use equation x=sin(angle) …
- Use Point polar
- Or use a vector say -Z then rotate it
Slope angle (radians) = Atan(Y/X)
Hello
it is more clear now. I think there was discussions on subject like that related to terrain
RhinoTerrain …
If you want a solid the subject is more complex if you want a solution that works in many configuration.
Offseting the curve and then moving it down seems the good way but the loft is not always good.
Grasshopper Offset fails ![]()
A good way could be to to things like here
Perhaps I miss something so a terrain guru can answer you.
I used plugin for grasshopper Bison | Food4Rhino,
and created mesh, but I couldnt split it or difference by other mesh
In result I need to convert this mesh to close brep and export to Tekla Structures.
But now I stopped at the stage split/difference ![]()
ERROR 23-04-1.gh (15.5 KB)
Hello
here is a way, it is lot of trial and error as if something work the other is not working so I have to choose the reliable tools.
To make the volume I choose to :
- extrude the main U shape (it must be a polyline).
- make a cone with each corner of the curve
- make an edge with each line
As brep boolean is not working for shapes that have so much common planes. I choose to convert everything to a mesh by using Dendro. And now I can do the split.
There are some plugin like Dendro (mandatory if you work a lot with meshes) and Nautilus (not mandatory juts used to heal the mesh)
ERROR 23-04-1 LD.gh (23.5 KB)
