any ideas how I can project a pattern like this on to a surface or some sort of array? Ideally I want it to go around the room just to illustrate some carving on a cornice in a 3d sketch
thanks
Would Flow along surface do the trick for you?
http://docs.mcneel.com/rhino/5/help/en-us/index.htm#commands/flowalongsrf.htm
thanks but I can seam to get that to work for this? am I missin
g something
- extract the surface and use
_ShrinkTrimmedSrfso it does not extend much below its trimmed area - now select the surface and run
_CreateUVCrv - near the world origin(*), the bounds of the surface are then created inside a rectangle curve
- place your pattern inside this rectangle so it fits your needs
- select the placed pattern and the bounding rectangle
- start the
_ApplyCrvcommand, then select the surface to tranform it back where you want it
(*) Your model seems far away from the world origin. If you cannot find the uv curves created, use ZS (_Zoom _Selected).
c.
