my name is felix , I am starting with rhino just a couple months ago .
I have a problem , and i will apprecciate your help !!!
years ago , an engineer that worked for the company that i am working now ,
he prepared the 3d geometry and make the wrap of the profile along the path and the result was very good ( see image )
now i have to prepar another file but with different dimensions but i already tried many times and in different ways and the result is not soo good ( profile was deformated and stay out of the 3d geomety borders )
as we can see on the right image the profile follow the path and always keep tangency 1434-ask.3dm (1.1 MB)
to the borders of the 3d geometry.
is there any person who are able to give a good advise ?
thanks in advance for your help
best regards
Felix
Hi Felix - the object in the file I posted is one I made just now using RailRevolve on the full helix -
if that looks good to you I guess you can use the same technique for your new object. Note the profile curve was cleaned up - it was self intersecting in the file you sent.
Hi Felix - I cannot tell, in the file you posted above, what parts of the file I should be looking at - most of the layers are off. Can you post a new file with just the helix, the profile curve, the base surface that you are working with as well as any other geometry that is important ?
1 . layer wrap from co worker which result is the goal
2 . 3d geometry ( wrap has to align an tan to the 3d geometry)
3. path to follow
4. profile to wrap
Hi Felix - the first thing I’d do is clean up at the start of the wrap - make sure the curves are where you think they are and tangent to the surface edge there:
Then offset the helix normal to the surface to the depth of the wrap profile
Then copy the helix curve forward and back to the ends of the wrap (Blue) and Pull these onto the surface (Cyan)
Now you have the forward and back extents of the wrap on the surface - now, I did this with the curves you have in the file and a Pull of the copies is a bit approximate it occurs to me that a better way to get these curves might be to Pipe the helix and intersect the pipe and the handle surface -
