We are looking for some further grasshopper definition parts that help us in the following conditions:
We have got a defintion that analyses the distances between attractor points and an amount of surface center points. Our definiton sorts the distances from small to bigger sizes and with some number slider compontens we are able to influence the catchment area of the attractor points.
The issue that results out of the definiton is, that the catchment areas are overlapping.
unt of surface center points that are all influenced by one single attractor sorted by nearest points. Further more we need the ability of influencing the catchment area (how many surface center points are influenced).
So may this helps. Just a quick modification. If a surface is attracted more than once, it will pick the highest value. So your result will be more smooth and without double extrusions. Made the example on the first two attractors.
Btw. check you initial surfaces. There are some doubled/overlapping.
You don’t have much to do. Tree Branch, Sort and Match Tree for every attractor. Plug them into the Merge Components to the first ones and it should work.
