Qualsiasi immagine importo è completamente bianca. Come faccio per risolvere la situazione?
Hi - please run the Rhino SystemInfo
command and copy-paste the result here.
Ciao Gaia,
probabilmente qualche problema legato a driver video.
Fai come Wim ti ha chiesto: esegui il comando _SystemInfo in Rhino e copia e incolla il testo qui (in questo modo si può verificare che driver video utilizzi).
ok grazie !
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Valutazione, build 2021-05-07
License details: Cloud Zoo
Expires on: 2021-07-11
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 3.9Gb)
Primary display and OpenGL: Mobile Intel(R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1) (Intel) Memory: 2GB, Driver date: 3-11-2013 (M-D-Y). OpenGL Ver: 1.1.0
> Integrated graphics device with 2 adapter port(s)
Secondary graphics devices.
Mobile Intel(R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1) (Intel) Memory: 0MB, Driver date: 3-11-2013 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Non supportato
Driver Date: 3-11-2013
Driver Version: 8.15.10.2702
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: n/a
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 0.0
Hi -
I’m afraid this hardware is too old to be running Rhino 7 without problems.
quindi dici che sarebbe meglio istallare un Rhino 6 o 5?
Hi -
Rhino 5 or Rhino 6 might work better on that hardware but are no longer sold.
If you change the Rhino 7 update frequency in the Rhino Options
from Service Release
to Service Release Candidate
, and then install the latest Rhino 7.7 version (you are currently running 7.6), you could try changing the OpenGL level to OpenGL 1.1 Software Driver
and see if that makes a difference.
Rhino Options > Views > OpenGL >
ok grazie per le info però io ho la versione di prova di 90 giorni …
Ciao Gaia,
non importa se hai la valutazione di 90 giorni, puoi scaricare tranquillamente le service release disponibili.
Quelle “candidate” sono service release ancora in fase di test prima dell’uscita finale (il più delle volte ci lavori tranquillamente).
La feature che ti ha segnalato Wim è nuova e permette di utilizzare un metodo di visualizzazione vecchio così da permettere ai tuoi driver (che sono del 2013) di poter dialogare correttamente con Rhino.
Essendo una nuova opzione, non è detto che risolva al 100% però tentare non nuoce (se funziona renderà contenti molti utenti rimasti indietro proprio per evitare di dover acquistare nuovo hardware).
Very interesting this new feature… could be the solution for those old users with old hardware that are still with V5…
I see that is available also in V7.6.21127.19001 2021-05-07
grazie! ,cambiando le impostazioni da Service Release
a Service Release Candidate
ho risolto .
Grazie a tutti
