Hello, I’m havin some troubles with the render view.
This is a closed polysurface generated with a simple loft between two circles and than offset surface. Also the loft has the same aspect. I don’t know why Rhino doesn’t smooth the preview.
Hi Pascal! Thanks for the answer!
I checked what you said but the option Flat Shade was not active…
I thought could have been the file because I downloaded it from the internet but also in a new one the same problem.
Yesterday I made the upload of Rhino…Do you think could it be the problem? Because I never had this kind of visualization.
Hi Alessio - there are two places this could be set - see also my second image for an individual display mode setting.
Hi Alessio – that is weird - is only one session of Rhino open? Try closing all Rhinos and start one new session and make the change…? Does the Shaded mode do the same, or only Rendered?
Hi Alessio - The shaded image you just posted looks correct; the Flat Shade setting not being permanent in Rendered is what I’d like to track down - is this a mode you imported from V5, or is it Rhino V6 default Rendered with some changes? Can you post the results from Help > System information?
No it should be all as a default. I don’t remember I ever did any change to the render mode…
Here is the System information:
Rhino 6 SR14 2019-4-28 (Rhino 6, 6.14.19118.15561, Git hash:master @ 8f0a84997c310a7ec1a42cf2704da8daa33e3e21)
License type: Educational, build 2019-04-28
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: PC
Hybrid graphics system.
Primary display: Intel® HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 12-21-2015 (M-D-Y).
Primary OpenGL: NVIDIA GeForce 610M (NVidia) Memory: 2GB, Driver date: 12-4-2017 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 388.57
Secondary graphics devices.
DisplayLink USB Device (Unknown) Memory: 0MB, Driver date: 11-29-2017 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-4-2017
Driver Version: 23.21.13.8857
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.14.19118.15561
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.14.19118.15561
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
Hi Alessio - click on Restore Defaults for the Rendered mode - does that sort it out? You might want to update both of your video drivers, btw - they are getting a little old.
