Problem with showing help steps (videos)
We have many pc’s at the moment who are no longer able to play help steps (videos). The error we see: “Your browser does not support the video tag”. See the included screenshot - the error in the right corner, next to arrow 4.
We have this issue on Win10 but mainly on Win11 at the moment. We use currently Rhinoceros 7.18.22x - but last school year we didn’t have this problem, but each year the machines get a new/fresh installation.
Is there a file or registrykey where we can change a value so this works for everyone?
I tried to copy the settings-Scheme__Default.xml file from a pc where the videos are shown to a pc where the videos wouldn’t play, and it still didn’t work. Maybe it is a combination of files/registry entries that solves it?
One of my colleagues found a workaround - but it only works for him, and we have a lot of students, not just a handfull, who experience this issue. He solved it by entering the ‘View’ menu and then select ‘Display Options’. In the ‘OpenGL’ segment change the value for ‘Antialiasing’ (to 2 for instance). And then save the setting and start Rhino again.
hi @Sander_Zegveld ,
pls run _SystemInfo in Rhino and post back the results.
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Educational Lab License, build 2022-05-04
Windows 10.0.22631 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 2GB, Driver date: 10-19-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.56
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-19-2020
Driver Version: 27.21.14.5256
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
Hi Sander -
There are 19 service releases that came after the version that you are running.
I’d at least update this on one machine and see if that makes a difference.
I will try that suggestion, but the pc’s that have the problem at the moment are currently in use for exams, so Ï need to wait until nomorrow.
You might also want to check into the Nvidia and Intel video drivers on the machines that work vs those that don’t. In any case it would probably not be a bad idea to update them all to the latest available.
my colleague already did update the Nvidia drivers to the latest version on one of the computers,but that didn’t help with the problem unfortunately.
Finally we could install the latest Rhino 7 release (SR37) but still get the same error/problem when trying to see the help videos.
