Hello everyone. As understood from the topic, i am having an issue projecting equispaced points to a half ship hull surface.
The main thing i am trying to do is to obtain the halfbreadth table of the ship hull form by means of user-selected amount of waterlines and frames. The “user selected amount” part and the rest of the code is already running fine so i am sharing only the problematic part.
When i connect the brep and the points to the project command, i get at least 1 or 2 points out of the hull surface. It depends on the surface a little bit i guess (because within the code it is possible to manipulate the hull surface and with every different surface the number of wrongly projected points change) but i wonder if there is an easy way of avoiding this to happen? Also i would be grateful if anyone can explain why i am facing this problem.
I am sharing the rhino and the gh file, thank you.
Gh Project 1.gh (6.3 KB)Point Project.3dm (1.2 MB)
