,Since 2 weeks I’m facing 2 problems with rhino 6 Problem 1: Rhino layout PDF - i’m having problem with layout printing, my detail viewport not matching with my lines and annotation after taking PDF. It will show fine in rhino and print preview, but the PDF results in above mentioned problem( refer image 01-05)
I dont know why this is happening in latest version of rhino 6 ,these are the ways of presentation if not working nobody can present any thing using Rhino
please help me out of this problem as soon as possible
Regard,
Ranjit
hi Pascal,
Here is my System info for rhino 6
Rhino 6 SR21 2019-12-17 (Rhino 6, 6.21.19351.09141, Git hash:master @ 4d373f64ffb55e3a8d607d9618590728d86fb1e9)
License type: Commercial, build 2019-12-17
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: BES17
As you can see in pictures detail view port and view is slightly shifted I analyzed the shifting position
it is shifting
aprox -3.038 on x direction
Aprox. +3.882 on y direction
when i am shifting Detail View-port ,my layouts print is coming at exact position of boundaries
Is there any displacement setting for rhino view port so that i can make it correct
i hope this study will help you find me a solution
Regards ,
Ranjit
Hi Ranjit - are your objects far from the world origin? Can you post a small file that shows the problem, or send to tech@mcneel.com (if confidential)
Please include a link back to this conversation in your comments.
Hi pascal,
this is the sample file for the same problem also screenshots are attached with it Problem with PDF output and Image Output.3dm (685.5 KB)
screenshot of Rhino workspace
Hi Pascal,
For the above Issue I found solution that when ground plane is turned on then this issue is happening . If we turn off ground plane images are neat and actual .
