Rhino PDF - bug
When printing an A0 layout via Rhino PDF the detail views turn out wrong (out of their frame).
Does not happen when I print to Adobe PDF…
Hi Morten - I’m seeing “something” here but only partly what you are reporting.
Which version of Rhino are you seeing this on? Just run SystemInfo and copy-paste that information here.
Rhino 6 SR28 2020-7-17 (Rhino 6, 6.28.20199.17141, Git hash:master @ b1f15b655bd1f5ae0d3d3257e3efdeb0a45630e4)
License type: Commercial, build 2020-07-17
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: LT169COBE
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 1-21-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P2000 with Max-Q Design (NVidia) Memory: 4GB, Driver date: 11-20-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 432.13
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-20-2019
Driver Version: 26.21.14.3213
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.28.20199.17141
C:\Users\morten\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.28.20199.17141
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.20191.1418
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.28.20199.17141
I would update both the Intel and Nvidia drivers first:
Update them manually.
The automatic driver update tools have a near 100% failure rate .
Use these links instead:
It could also be that “clipping box” or “Enscape” plug-ins, but I’d do the driver update first.
Any luck?
