Hi! I’m trying to make a hole through of an object using the roundhole tool, but when I make the hole, it doesn’t go through the other side of the object, it pushes the bottom out instead creating a cylinder on the other side, like this:
This is the object I’m trying to drill through and I’ve marked the spot where the hole needs to be with a cylinder. Can anyone tell me what i’m doing wrong?
Thanks!
