Hello
Actually, you can also create a negative reinforcement parameter that punishes the algorithm when the curves intersect, which will also be an interesting way to achieve similar results, however if might take longer to converge into a solution!
Yep that’s it! So simple and efficient
minimize bounding of 2 geometries.gh (17.2 KB)
Hey there! I’m new to grasshopper and trying to prevent my 3 initial objects from intersecting after running the Galapagos solver. They may collide/ touch but should not intersect. Could you help me out?
test 1.gh (14.0 KB)
