hi guys,
i’m experiencing a really annoying problem when i try to move with the gumball. it skips in increments instead of moving smoothly…have a hit a setting that causes this? i’m not sure when it happened…how can i make it move smoothly again?
hi guys,
The only problem I see - You didn’t read the manual.
“Right-click the Gumball pane in the status bar to access options.”
if you left click on the white circle on the gumball, a menu will pop up…look to see if “snappy dragging” is toggled on, versus “smooth dragging”
snappy dragging will snap to your snaps such as point, intersection, etc.
(forgive me if I am incorrect here…)
Best Regards,
Julie
thanks a lot for your replies cadmaster and widizrd.
i have smooth dragging checked already but it is still skipping in increments as i try to move it…any other idea what is going on here ?
(it skips by increments of one unit)
Grid snap
it’s actually not snapping to the grid (but still it moves by increments of one).
i tried making Grad Snap 0 and it made no difference
aAAHHAHHH I got it. GRID SNAP! yes, i had the grid snap box panel pressed. duh. THANK YOU !
(changed category to Rhino for Mac)
