Hello, I am trying to 3D print a holder which I modeled up in Rhino 7, but I get a notification that the model has 189 non-manifold edges when I import it into Bambu slicer. Before I also had an issue where the slicer would fill the whole part with the circle and the supports with one layer, but I am now unable to reproduce it, now 2 of the 4 supports are disconnected from the main part when I use the Repair function in the slicer.
The _showEdges command in Rhino, says zero manifold edges, but when I use the _mesh command and set it to use many polygons, it closes the side which was also closed in Bambu slicer, If I use the middle value on the slider it looks normal, the _meshRepair command shows quite a few errors/warnings in both cases, some of them are: “Mesh has 3 extremely short edges.”, and “Mesh has 512 naked edges.”If it is relevant information, the threads are imported from a model downloaded online.
I have attached the Rhino project file, and the exported .stl file.
Holder.3dm (2.3 MB)
Holder.stl (5.4 MB)
I hope someone can tell me what am I doing wrong, and how to correct it.
Thank you in advance
