I dock the Curvature Graph Panel, resize it until only some controls are showing. Then pop the Curvature Graph Panel out again. The panel will have no scroll bar, so it’s un-usable. A restart seems to get things back to normal, until you perform the dock, resize and pop out. Then exact same problem will be back.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\XYZ\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.3\Substance.Win.rhp “SubstanceImporter” 2.0.3.0
I already made Windows run Rhino on the GPU. Not sure if that is the problem with windows not using the GPU, or actually using the GPU cause problem. Well, don’t have money to get a proper high-end workstation, so had to make this work on my laptop for now.
So it’s my graphic configuration that is causing the problem not because some bugs in opengl or something?
Thanks for suggestion for updating intel driver. Both driver for intel on-broad and GPU driver is the latest ones. So maybe the newer ones are the problem or again something else.
