V-ray on Rhino 6 worked perfectly til recently, it only renders top view, even if I have my perspective window maximized. Has anyone run into such a problem?
Hello - my guess is that is a setting in Vray for which view to render. Rhino Render has this setting - it may be that VRay pays attention to that, or has its own setting someplace.
Hi Pascal, thanks for your solution! I reset the setting on the panel and the problem is solved! Thank you so much!!
